- 26 Dec 2013
- 404 Not Found
I am about to start making all of my custom wiring for my new Prodigy build. I am creating custom length cables directly from the fully modular PSU to each component.
With my previous build, I used 4mm Teleios cable braiding. The braiding is good quality, but as it's more of a plastic, it's to rigid and doesn't like tight bends etc. As a the PSU area in the Prodigy is going to be a tight fit (even using 10mm motherboard standoffs on the PSU bracket to give extra room), I was looking at using paracord as it seems a lot softer and flexible.
Could somebody recommend where to get the right paracord, I think I am going to go with 3mm to keep the bulkyness down. I will be using mainly white braiding, with several strands of black thrown in.
