Cable Braiding Question
4 Dec 2009
Worcestershire
I am thinking of braiding my CPU 8 pin (30cm), motherboard 24 pin (30com) and my PCIe 6+2 and 6 pin connectors. Could you guys just check over the stuff I am looking to buy as I am a complete noob when it comes to braiding :D
10m of black 3mm sleeving
10m of blue 3mm sleeving (is 20m too much/little?)
1m of black 3.2mm heatshrink (will I need more than 1m?)
Thanks
are you talking about eachwire seperately? if so it sounds about right. that said i'm trusting your maths. depending on whethe you go for dense weave braid the 3mmmight be too tight depending on the thickness of your cables
