Cable braiding?
2 Jan 2011
Edinburgh, Scotland
I'm new to cable braiding, and I was wondering if it would be good to get this?
Pin-Remover by MOLEX - The Original PR-MOLEX 24,20 Euro 24,20 Euro
Sleeve SMALL - ORANGE SL-S-OR 7,95 Euro 7,95 Euro
Sleeve SATA - ORANGE SL-SA-OR 5,95 Euro 5,95 Euro
Pre-Cut Heatshrink SMALL - WHITE HSC-S-WH 3,99 Euro 3,99 Euro
Heatshrink SATA - WHITE HS-SA-WH 3,20 Euro 3,20 Euro
Subtotal: 45,29 Euro
Total: 45,29 Euro
(EU only) 19% VAT included: 7,23 Euro
It's from that place where the guy draws on peoples packaging ;) (don't know if i'm allowed to say the name so I won't)
You can get just as good quality from the UK. Just google "10mm Blue Cable Braid - Sleeving *Dense Weave*" They also do the Pulse Modding ATX Pin Removal Tool. Murdermod is overpriced. The braid mentioned above is very good quality.
murdermod are a brand so you can mention them from what i am aware, just no links to their webstore please.
as they are a one man in a shed job so its not like they are a competitor, but just dont link to them as i say.
personally i think their kits are quite reasonable.
i purchased all of my braid from UK based suppliers and it came in at about £60
it would have been cheaper to purchase a murdermod kit, but it depends how many different colours of braid you want really.
hope my input helps :)
I picked up a murdermod kit on here for £20. Enough 3mm to sleeve my 24pin and 8pin extenders, and some other stuff besides.
Personally though after doing it all, I'd recommend to anyone to just buy pre-braided extenders. Works out cheaper and the ones I have are a much neater job than I could ever do.
Am new to braiding myself. Just wanted to link to a tutorial that i think is good (although I wouldn't really be able to tell since I don't have the experience). Maybe you guys can tell me what you think.
Sorry for small hijack of this thread :(
