Cable Combs width
I can't give you an exact answer but I can tell you I built my own extensions with the Cablemods Modflex cable system and even the narrow cable combs were too wide. I tried both narrow and the stealth combs E22 sell and neither fit properly. The combs are loose enough that they fall down the cables by themselves when the cables are vertical
Not sure if the kits use the same gauge of braiding but my experience might help
