Cable extensions advice please
2 Nov 2021
Cornwall
Cable extensions
I have just bought a corsair rm850e psu and want to add cable extensions but I keep seeing that I can't use just any type.
The corsair ones that I've found seem to be very expensive.
Does anyone have any recommendations please
Cable extensions such as these just plug onto the ends of the existing cables and can be used on any psu. These are much cheaper than full cable sets as you can buiy only the ones that will be visable. The downside is the extra length of cables that you now need to hide.
If on the other hand you mean replacement cable sets then they are psu specific so you need to make sure you choose the correct set otherwise you could end up frying components. They look nice but some are almost as much as the psu itself which seems ridiculous.
