Cable hub
4 Jul 2013
hi all.
So, I use a programme called zwift - essentially a cycling simulator.
The setup is in my garage and I take my laptop out whenever I use it.
To do this I have to plug in the hdmi from the tv, usb from ant+, usb from handheld keyboard thing, and the power cable.
I wondered if anyone knew of a hub whereby I could leave everything connected then just insert a single cable into the laptop and be good to go. Of course the power cable would still need plugging in but I’d like to make some neat cable routing and just be left with a hub connection. I guess a bit like a home media hub that you get in modern houses, I’m not against a cable for tv then the rest.
So perhaps a usb hub bit thought I’d ask if there was a usb and hdmi type of unit
Have a look at laptops docks. Most will require minimum two leads though, one for video and one for usb. Ones that offer video over USB are rare but there are a few that exist.
You should be able to run some sort of docking hub type thing off the USB C port. Would give you a couple USB A ports, and a display output.
