Cable management - advice please
21 Jan 2006
Hi, I need a solution to sort out the cables behind my desk...there are a lot! I need some sort of cable management system or something that can make it more tidy...any ideas for what I can do to help achieve this?
All advice welcome - thanks.
Just cable tie them up out the way thats the cheapest. Or buy some plastic trunking and mount it up out the way and run the cables in that
dunno if you have one near you, but poundland does the cable tidies, basically plastic coils...works ok and cheap :D
