Cable Management Grommets?
16 Nov 2011
Lisburn
Hey I have basically just cut the correctly placed holes in the back of my motherboard tray for a bit of cable management, I was wondering is there any where you can buy the grommets which are in place on most motherboards now a days with cable management?
Thanks L15T3R
Not the proper ones I think you're after (As pictured on internals of Corsair cases?), I spent ages trying to source some myself, but yeah either the sort at Halfords (O rings of various sizes) or simple rubber "blowhole trim" will protect the edges from damaging the wires
Thanks very much guys! luckily there's a halfords reasonably close to me so I will go down and check them out!
Thanks again for the help!
L15T3R
Thanks went on and found something to suit my needs but its 100 assorted, so i will search around for specific ones if I can get them cheaper
Thanks for your help
L15T3R
