Cable management help!
5 Aug 2006
Derbyshire
I have an antec 300 with 5 hard drives and a SLI PSU with braided cables that are not modular.
I have poked all the gfx adapters that I do not need behind the CD drive area to get them out the way, but the case still looks like this:
http://s151.photobucket.com/albums/s126/mglover070588/?action=view&current=DSC01106.jpg
Please give me some pointers I am clueless!
The side of the case is hard to put on. The hard drive power cables are a huge PITA as they are braided as well.
The PSU has so many cables!!
(The rig is in my sig).
you know if you use
instead of URL we can see it in post instead of following the link, thinking on your cable management and get back to you, lol
see :)
Yeah I was just double checking if the 300 had it, my 1200 does, can you not use the cable compartment behind the mobo if you take off the left hand panel, you may find that buying a couple of extensions for the main 24pin and 8pin mobo leads is necessary for them to fit all the way around, but obviously you can tuck away any cables you arent using, end up with something like this
even the SATA cables, take them through the bottom hole nearest PSU then bring them back out the hole nearest the source, HDD, optical whatever, it all helps
