Cable Management
25 Oct 2006
What do you suggest I do to sort the cables out on my machine? The tagan PSU cables are very stiff, especially the mobo atx cable.
I will most likely be purchasing an 8800gts soon and have been told its about the length of an atx mobo, so it will be a very tight fit by the looks of it, and the cables will need sorting out.
http://img72.imageshack.us/img72/9531/p1013174gy6.th.jpg
and
Thanks for any suggestions :)
(For some reason the first image would not post as a thumbnail)
