Cable modem connected to Ethernet port for ADSL wireless router
5 Dec 2005
I am using a Motorola cable modem (one USB port and one Ethernet port) to access the net. I would like to connect that to a router; to share the network.
Right now I do not have a router (i.e. one Ethernet WAN port , and 4 Ethernet LAN ports) to do a sharing, because with this type of router the connection straight forward
But I have got two ADSL Wireless modem routers (NETGEAR DG834G V1and LinkSys WAG54G V2.0 (RJ 11 port and 4 Ethernet LAN ports)
Can I use one of those ADSL Wireless modem routers ? and connect my motorola modem cable to one of its LAN Ethernet port ? does it have any drawback ?
You can't hook your cable modem up to the ADSL routers switch ports and expect to run more than 1 PC if thats what you're trying to do
