Hi, I am moving house where finally there is cable available but I know very little about it other than it is fast and the tv packages with tivo seem pretty good due to only having had adsl before (with a max speed of 1.5 megs).
My main questions are:
1 - The previous owner had Virgin there already so there should be no need to dig anything up but I assume they deliver the boxes & set things up for you, is that correct?
2 - Given the above, does anyone know how long it would likely take from asking them to sort me out to it getting done. I have around a 2 week overlap of houses & would really like to not be without the internet when that period is over. If it is likely to be longer than 2 weeks, could I just order sooner without knowing things like the phone number etc etc?
3 - The cabling that has been left is a mess, with cables coming down from the ceilings in a couple of rooms, if the above is true is that something I can get them to sort out & tidy up considerably? (one or two of the cables are Sky ones I think but in the same place as what I believe is a virgin cable).
4 - I know there is virgin anywhere but does virgin have the same kind of functionality as sky multiroom & if so is it basically the same kinda thing of needing a 2nd box, more cabling & pay a bit more on top of the subscription?
5 - Are there any mind blowingly obvious (to most) I should know or do before getting it?
Or would it be like my current situation where my office has a router & unless I want cables running along the floor it is the only room with wired access.
