Proxfx750 just got it today. The thing is my crosshair v formula z has 24pin - 8 pin and 4 pin to push overclocking. The psu came with 24 and 2x4pin which ill plug into the 8pin slot - buy i wanted to make use of the 4pin slot too
Cant use the 2nd cable cause im alteady using the 8 pin and for the 1st cable if its okay for now but what if i wanna crossfire :/
according to 8 Pack you don't even need it for that, asked a similar question when i got my mobo in sig, board has an 8 and 4 pin atx plug but my psu only has an 8 pin plug.Unless your doing extreme overclocking then don't worry![]()
According to: http://rog.asus.com/216552013/cross...g-fx-8350-to-4-8ghz-on-crosshair-v-formula-z/
''The Crosshair V Formula-Z is equipped with an additional 4-pin CPU power connector. While fitting it isn’t necessary, it can help the stability of high-level overclocks such as the one we’re attempting here. If your PSU doesn’t have one spare, don’t worry!''
