Cable Router Question
28 Dec 2002
Northern Ireland
Hi Guys,
I was thinking of getting this router
D-Link RangeBooster N 650 Router DIR-635
It says it is for cable users but i wanted to keep my sky router, turn of the wireless in it and then use this just for the wireless access? Will this setup work and has anyone had any experience with these routers?
cheers
ace
A few cable routers can be turned into a wireless access point and this one appears to be able to do the same - should be fairly easy to do.
Yeah will be fine. You just need to turn off the wireless on your Sky router if you don't want it and turn off DHCP on the Netgear or there maybe a mode which makes it into an Access Point which may do that for you. Make sure you plug the Netgear into your PC first and set up anyway :)
