Cable Router?
18 Feb 2006
Hello all, my wireless router is now becomming a total pain.
It's freezing and locking up left right and centre, i have installed newest and older firmware and no change so we have decided it must be the unit itself.
What wireless router would you recommend is the best for cable around?
Sub £100 if possible.
TIA
s-
Nickg said:
Hi is it right that you have to pay $20 euro's for this firmware?!
:eek: no! :eek: 'tis FREE (donationware - if you like it consider donating something)
You are probably thinking of the sveasoft firmware
Special DD-WRT standard/micro distribution which adds PPPOE-Relay (only in standard) and Per User Bandwith Control
updates will be provided per email (on request) and in a special forum category
it just add's a few features that you really wouldn't need. the normal ddr-wrt firmware is completely free from the link i gave you:) just make sure you are downloading the correct firware for your router:)
