- 8 Jan 2003
- Scotland
I'm looking to do some ethernet cable runs to deploy Unifi kit in my new build house. The internal walls are timber frame with plasterboard. They appear to be filled with some yellow wool like insulation (discovered this when wall mounting my TV).
I've linked to a couple of floor plan pictures showing where I want things to be placed. The OpenReach fibre ONT is in my lounge (unfortunately). I'm hoping to locate the downstairs AP in the dining room with the upstairs AP on the ceiling on the landing at the top of the stairs.
Ground Floor: https://imgur.com/a/RiW6zLV
First Floor: https://imgur.com/a/VGhgBSH
My original plan was to locate the network gear in the cupboard under the stairs (marked ST on the ground floor) but I don't think that will be practical for running cables. So my plan B is to locate the network gear in bedroom 4 (which is unused) in the area with the orange box.
The orange box in the downstairs WC is a boxed area containing a soil pipe. This has 3 access hatches. Do you think it would be possible to route a cable in this to get it upstairs? I was hoping to run a cable from the ONT in the lounge under the edge of the carpet, through to the WC into the boxed of area. Run it vertically in there and coming out into the storage cupboard upstairs. I can then route this through to bedroom 4. From bedroom 4 run up into the loft and then down to the upstairs AP. The downstairs AP might be trickier as new builds these days don't have floorboards but those giant chipboard sheets, so not sure who to run the cable for this one yet.
My last ditch plan would be to run the cable outside along the wall and then up behind the rain water gutter pipe but that would be a last resort.
Does all this look do-able? Any better ways of doing this?
