Hello, well I have the Seasonic 600w, right...
Well tis arriving tomorrow, I presume its going to be the one which isn't sleaved.
What cable sleaving ktis are there are they hard to install, also whats the "heatshrink tubing" ?
Isnt it just one sleave which goes over, as on ocers it is described very easy to isntall without having to take off the molex connectors. They say the following :
Thanks guys, also what do you recommend !
Got a Sunbeam Samurai case by the way, I bruoght it before I knew abot OCERS so dont take the mick!
Vantec Cable Sleeving Kit - Black (CA-001-VA)
The inside of a computer case is usually a mess of cables and wires. Power cables get tangled up and loose wires can be damaged from fans or other jagged edges inside the case. The Vantec Cable Sleeving Kit is the ideal way to eliminate these problems. The braided sleeve is expandable up to 150%, making it easy to slip over any plugs or connectors. Made of flexible material, the Vantec Cable Sleeving Kit will not break or crack. Sleeving your cables not only makes the inside of your computer look cleaner, it will also improve airflow, reducing the heat inside the case. The Vantec Cable Sleeving Kit is also ideal for bundling cables and wires outside your case as well.
