Cable Sleeves Question?
15 Aug 2003
Christchurch.
Simple really – are there any sleeves out there that you can just slide over the existing cables without taking off the connectors?
You can do that on the sata, fan cables etc with most braid as it expands well. Not sure about the heatshrink, but I would imagine if you get 4:1 it might work.
There's no way it would do the larger (PSU) cables though.
