cable sleeving
19 May 2011
hi i bought a cheap case and although i've got the psu cables looking all nice and tidy the front panel cables are spoiling it a bit, what size braid and heatshrink would i need to sleeve the power/reset buttons and usb/hd audio cables aswell as my fans? I'm guessing 3mm braid and 3.2mm 2:1 heatshrink would do the job?
You guessed right 3mm is perfect for fan cables and single PSU/Molex with 3.2 heatshrink. USB cables will need a little bigger though as you need to be able to get the ends over. 6mm should stretch ok.
For the front panel connectors on my second rig, i went with a set of pre braided cables, (im a lazy git).
Pity though i couldnt get them in blue to match the other bitfenix extensions.
