Mason64 said:RJ11 Cable on both ends
Talbs13 said:The one that actually receives the Internet. Normally a black cable plugged into the Cable Modem for Telewest.
They shove RJ45 on the end to plug into a cable modem in NTL land ? Weirdosormicoft said:fibre optic - coax - rj45
sormicoft said:no oh dear oh dear,
its fibre optic to the box then co-ax to your master- co-ax to the modem then rj45 (or if your really wierd usb) to the pc or 360
Talbs13 said:Thank you! At least someone is talking sense. I used Telewest as an example. They supply Cable not BT Rubbish. NTL, Telewest, Blueyonder etc is what i mean.
Can you you tell me what the 'master' is? Is that like a local junction box in the area which distributes it around the houses?
