Cable tie question
29 Mar 2007
....Im almost embarresed to ask this because i dont think its right but none the less, ive been doing some cable management in my case, and ive put a cable tie around my sata cables and pulled it fairly tight, can this cause issues?
Since ive done it, i seem to be getting loads more HDD activity, aka i can hear more hdd activity, hdd light on a lot more..
It seems stupid to me but that is the only thing i can link it to :confused:
The worst you could do it make a break in the cable but id oubt this would lead to more HDD activity. It would just be either working or not.
Did you put the cable back into the same SATA port on the Mainboard?
Yeh thats what i thought, its no where near tight enough to break the cable, they were put back in the same sata ports on the mobo too.
Quite puzzled as to whats caused it! lol
Squashing / kinking cables does cause resistance and can cause a slow down of data transfer. I doubt you will get any interference from the power cables inside your PC as the are low voltage.
If you have a high speed DATA cable (SATA, USB2 ..etc) close to another high speed DATA cable or a cable that is drawing a large amount of current (Mobo ATX, GFX AUX supply) then their is a possibility of crosstalk if the shielding & grounding in the high speed DATA cable is not good.
