Cable Wraps
12 Jan 2006
Hi Folks
Just a quick question. Does anyone know where I can find Cable wraps (looks like fishnet stockings) so I can tidy the power cables away when I start my new build. I have looked around the OcUK website and cannot find them anywhere.
Thanks
Yep that stuff is pretty good ^ ^
GraemePaul, just for the record, the type of stuff you're looking for is cable braiding.
GraemePaul said:
Hi Folks
Thanks
sounds like that will be some kinky case u will have there mate
:D :D :D
Cheers folks,
Yes it will be a kinky case. I expect it to go out moonlighting at LAN parties to pick up some big Beefy Quad Core SLi'ed monsters who can give it a good seeing too...
I was intending to get a Corsair 520W PSU however from what I have found on the web only the main cables (MB Power) have braiding the others are just plain black. Very stylish yes but I want to keep everything wrapped up as neat as possible for airflow.
here's a crappy pic i posted in another thread. you can see the standard molex cables on the hx 520w......
