 - 28 Oct 2020
Hi, I bought a cablkemod kit, this one: https://www.overclockers.co.uk/cabl...-hxi-and-rm-yellow-label-black-cm-169-cm.html
I have a Corsair HX 850 but the 24pin mobo cable doesn't fit at the PSU end
If I line it up with the top notch the holes dont fit, ut they do if i put it one to the side but as you can see there;s gap of 2.
Hers how its supposed to look with the default corsair cables:
I know its the HX and not the HXi but pretty sure the connections are the same. I dont get it?
