Cablemod vs Bitfenix cables
1 Apr 2019
Looking for some nice PSU cables to finish off my build. Two options as I want red cables:
https://www.overclockers.co.uk/cabl...xi-hxi-and-rm-yellow-label-red-cm-16b-cm.html
https://www.overclockers.co.uk/bitfenix-alchemy-2.0-psu-cable-kit-csr-series-red-cm-248-bx.html
Has anyone had experience with both kits? This is purely aesthetic modification, I am curious if there are any substantial differences between the two in quality or anything else.
No experience but I like the look of the cablemods kits. Bit pricey but given the hours it would take to do it yourself probably worth the cost.
Id go with cablemod, bitfenix are more a cotton type of material and they tend to look shabby and fray some, the plastic type like the cablemod is more durable imo
edit actually they both look like cotton, id look for plastic type
Thanks chaps.
Can you buy single cables only from anywhere? I only really need ATX 24 pin, CPU 8 pin, and 2x PCIe as all other PSU cables are hidden.
