Cables
7 Jul 2008
Do motherboards from OcUK come with all the cables required, eg SATA cables, or do they come with SATA devices? Do you get them with OEM SATA devices?
Thanks.
It depends on what mobo, certain manufacturers supply a certain number of cables with certain mobos (e.g. my mobo came with 4 SATA cables and 2 E-SATA cables, etc). Cob is of course correct, with OEM hard drives (and OEM optical drives) no cables are supplied. However, with retail hard drives (and retail optical drives) cables are usually supplied.
If you were interested in anything specific, you could have course ask again and someone who has purchased the particular mobo (or drive) may enlighten you. Then again you could always send OCUK a webnote.
Thanks. The Gigabyte GA-MA770-DS3 is the mobo, is this a good board? Not planning on overclocking or even running high strain apps or games! Just needs to be a futureproofed business machine. Planning to go with the AMD Athlon Dual Core 5600 and 4GB Corsair XMS2. Would welcome any oppinions.
Just got that gigabyte board myself, came with 2 sata cables 1 ide cable (2 connectors) and a floppy drive cable. The board has been great since installing at the weekend with a 6000 x2 and 4 gig ram
