- 2 Jan 2014
I have recently rebuilt my PC and bought a Game Max Cobalt Tempered glass case because it fitted my budget and I was able to fit a 280mm radiator in the top comfortably.
The case looks roomy but I appear to be having difficulty with the Corsair modular power cables and the shear amount of equipment I have in the case. The cables are very stiff and I have spent hours trying to re-route the cables, so I can fit the tempered glass side on but to no avail.
For this reason I want to modify the wiring in the case so that I have the correct cable the correct length and the correct connectors.
Is there any cabling solutions that might resolve the issue, all I can find is cable extensions but this would just make the problem worst.
