Hi fellers, quick question really.
My dad just asked me the following "I want to set up a network cable connection from the router in your bedroom to my computer in the basement. The cable should run through the bedroom wall outside along the wall and down to the basement.
Check first but I think will need to get Cat 5 or Cat 6 external cabling, with connectors and a cheap RJ 45 crimping tool plus some cable clips to pin the cable to the wall."
Is that right?
Is that right?
