CAD and Gaming build sub £1,000. Help?
30 Nov 2013
UK
My neighbour is looking for a PC for Fusion 360 and gaming.
His budget is ~£800 with a little flexibility.
What's available?
Is the I3-8350K worth considering or should it be a hex core I5, what about an AMD CPU?
Would like a 1060 for some gaming prowess.
Would like a 250GB SSD + mech storage.
Does not need O/S or peripherals.
Thanks.
My basket at Overclockers UK:
  • 1 x OcUK Gaming Citizen Gaming PC - AMD Ryzen 5 2600, RX 590 8GB Graphics ***THREE FREE GAMES*** = £770.94
    • Memory:Team Group Vulcan T-Force 16GB (2x8GB) DDR4 PC4-24000C16 3000MHz Dual Channel Kit - Grey (TLGD416G30
    • Graphics Card:powerColor Radeon RX 590 Red Devil 8192MB GDDR5 PCI-Express Graphics Card
    • Solid State Drive (optional):TeamGroup 480GB L5 Lite SSD 2.5" SATA 6Gbps 3D NAND Solid State Drive
    • WIFI:Unwanted
    • Operating System:Unwanted
    • Security Software:Unwanted
Total: £785.04 (includes shipping: £14.10)
pre-built. ask for a better PSU - like Formula or bequiet Pure 10
slap in freesync screen for gaming and 2nd screen acting along with cad
https://www.overclockers.co.uk/aoc-...reesync-widescreen-led-monitor-mo-04l-ao.html
Fusion Rendering is done via CPU, GPU helps with models displayed in the view point, bigegr the work and more vectors/polygons the harder the GPU will work etc
Most processes in Fusion 360 and other CAD programs are still single core, so lean towards clock speed over the number of CPU cores. A 3.5 GHz Core i5 is better than a 2.4 GHz Core i7. CAM, however, is able to make use of multiples cores and thus certain CAM processes can benefit from not only higher clock speeds but also having multiple cores.
intel would offer the perfect blend or Cores and speed... at cost
the above pre-built does offer good value for cash
build yourself. intel+ rx = 4 free games, 2 with intel including BFV
Total: £918.95 (includes shipping: £13.20)​
