CAD Machine (spec me)
11 Mar 2009
Wales
Hello everyone,
A friend has asked me to spec him a machine for CAD (AutoCAD Architecture) to be specific.
I have tried to spec something up but i keep coming in over budget by a fair way. I am starting to think that realistically the budget is too low.
The Budget £500
Also needs to include win 7 64 bit
He will be doing 3d cad with it. Could anyone here have a go at speccing something for me please.
I believe it will be difficult task to create something with an adequate spec for his needs in the budget he has given but please prove me wrong!
OP: Depends all on what you want the PC to do. My final year project had a whole CAD tractor and made my laptop (with Intel rubbish graphics) so badly it was unbearable, but my desktop PC (see sig) was fine.
If you are doing small-mid complexity CAD work, then any old modern PC is fine.
If you are doing complex work (say a whole car loaded up at once) then you need a powerhouse.
Its worthwhile getting a low end ATI Firepro or Nvidia Quadro graphics card it makes a huge difference even on really budget spec pc because these CAD orientated cards can do the work instead and your software supports it too.
I would also confirm that Autocad will run on Home Premium. On know from past experiences that a fair few CAD packages will not run and are not supported on a non Pro OS.
Oh and like you said £500 buget for a Workstation to produce money making content on is not advised at all. Its like a carpenter or fitter using a drill that was a tenner from wilco rather than a good DeWalt ;)
+1 on this.... I've spent too much time cross flashing and the performance difference is like night and day.
BTW OP really needs to be looking at a 2600k or 2500k at minimum. CAD is really intensive especially if you're looking for silky smooth performance.
If you're happy with lag and want to keep to a smaller budget then don't bother with this advice :)
