cad mechanical simulation? software
14 Dec 2005
not 100% sure what I'm looking for is called.
want to be able to try and design fairly simple designs, just using hinges and slides really
dowloaded the demo uf autodesk 360 which lets you make components and assemble them using different joints, revolute and pin slide create the joint/motion i want but I cant get them to work together like I want,
I might just need to learn it better (only skipped through a few youtube vids ect).....just wondering if there's a better program to use ?
