CAD over remote desktop
On a LAN or broadband connection?
I've tried using InDesign via RDP on a 4Mb conneciton. Not good. You can turn the pictures off in InDesign to save on bandwidth if working on text. Possibly something similar in your software?
For Your information, AutoCAD will allow a "Stand alone" licence version to be installed in 2 locations, as long as you do not run them concurrently!
I tried running over RDP on my Infinity Broadband (65Meg) but it was bottle necked at the office end! and like wading through treacle!!
So I have the Product Design Suite installed at my office in Uxbridge and at Home 75 miles away in Swindon. both are registered with the same Licence! all legal and approved by Autodesk as, obviously, I can't run them concurrently (at least not easily).
Would be fine over a LAN where sub 1ms pings are achievable. Over the internet it will be horrendous, you wont get much work done as you'll end up rage quitting pretty soon.
Whats the Spec??
My PC at home is actually less powerful than my PC at work (AMD Llano Quad Core compared to a Xeon 8 Core at work) but it runs quite smoothly here no probs! :)
i3, 3gb ram and some integrated vga, i think its an hp G67, not tried acad on it, perhaps ill give it a whirl
Give it a try! you might be surprised!
I used to run it on a Celeron Dual Core Laptop with 4Gb RAM and an Nvidia Intergrated Graphics of some sort... Ran quite smoothly!, even Inventor Ran on it!!
It depends on your network. I can run photoshop nicely over RDP on a gigabit network.
Was going to say. I regularly RDP to a server running RemoteFX and I can even run through a 3DMark benchmark on it, or play a game!
It's easily possible to get a good experience over RDP, but it's unlikely for most people!
The problem I find with remote design is that the screen draw is often inaccurate. So you could have perfect latency, but it still won't render the view properly. It's not completely gone but things like missing rules etc make it unproductive. Application dependent.
