Hi all
My old GPU messed up last year so I've been using my i5-based machine with inbuilt graphics for a while. it's got 8Gb RAM and an SSD so it's not been too bad, however I've started suing AutoCAD 2016 and it's stressing the machine a bit.
It's also - as you might imagine - not too great with games, anything beyond L4D2 gets far too blocky to be playable so I've switched to PS3.
Would a dedicated low-end CAD-specific card offer any advantage over a standard consumer card? I note that the technical specifications for the CAD-specific really don't look that great in comparison, for example clock speeds at equivalent price points.
I'm looking at around £100, which just about gets me into the bottom end Quadros and Firepros, but it feels like I'd get better bang for buck from something like an R7. I'd consider second-hand or ex-demo for either type.
Any advice or recommendations appreciated.
I'm only running one monitor but will be looking to shift to 2, at present I'm running VGA only as I use an analogue KVM switch between my machine and my laptop dock but will be upgrading to a digital KVM when I change monitors - outputs on graphics cards could therefore drive monitor/KVM switch upgrade choice, although laptop dock is displayport or VGA I'd be happy to use a converter if required.
Cheers!
Cheers!
