- 15 Sep 2014
Good morning..!
I'm looking to replace / upgrade my self-built CAE workstation with something a bit more capable, and am trying to decide whether I should go down the route of the 8-core Haswell-E i7 or 2 x Xeon e5 CPUs.
I use the PC for CAD with pretty large assemblies, component FEA, and Computational Fluid Dynamics. The CFD is the real killer.. solutions are incredibly resource-hungry and my current build is struggling. The HDD is on it's way out and I want to upgrade to SSD, but that is pretty much going to drive a new build. The current setup is 5 years old, so due an upgrade.
Currently I have a 1366 4-core i7 and 16GB RAM, and will likely need 32GB Ram and at least 8 cores. While I'm fairly computer-literate, I'm certainly no expert so it may be best to deal with me in fairly layman's terms!
I was initially looking at only the i7 range, and trying to decide whether I would be happy with 6 cores or would have to stump up twice as much for 8; then decided to look at Xeons and found I could get 2 6-core CPUs for the same money as a 8-core i7.. and figured 12 > 8 = win. I looked in to server boards, but my CAD software won't run on Win Server, and needs Win 7.
So the advice I was hoping to get is..
1 - Would you recommend i7 or Xeon for my usage? Bear in mind I would like to keep the upgrade under £2k.
2 - If i7, I think I could probably figure out the hardware to buy.. I fall short on Xeon and dual-socket because I have zero experience. So.. what CPU - either 6 or 8 core - and motherboard would you recommend? I need to run Win 7 so I think that rules out server boards. I have my eye on Supermicro's X10DAC workstation board - is this a good bet?
Graphics is a foregone conclusion - I am tied to an Nvidia Quadro due to my CAD program. For the original build I foolishly didn't think to check, so got an incompatible GPU and had lots of runtime errors.
I think that's it.. I'll try and keep this an acceptable length!
Think that might be a bit on the pricey side.
