Hi, I have just got my new cal and have a xonar dg sound card.
How do I set these headphones up to get the best out of them?
1. Do I plug the 3.5mm jack into my sound card and if so which port?
2. Do I have my sound card set as default device under the windows sound options?
3. What options should be set in the Xonar DG Audio Center?
The only way I can get them to work is to plug them into the front jack socket on my pc case, and set the headphones to default under windows sound options but is this using my sound card or the on board sound?
hope that all makes sense?
