Calculating Distance
4 Jul 2004
aberdeen
Hello,
I have a list of locations and a list of users (in longitude / latitude). How can I make a query in mysql so it is like (in plain english here:)
where longitude is between x-100 and x+100 and where latitude is between y-100 and y+100
(if x was the users latitude position, y their long)
thanks
Set latlow to be x-100 and lathigh to be x+100 and select all records where latitudes is greater than latlow and less than lathigh. Same for longitude. Or is that not possible?
if the distance calculation is simply for working out an order, ie, the closest location to someone else, then just work out the 'distance' with pythagoras theorem and order by that :
select location.id, min(sqrt((person.longitude-location.longitude)*(person.longitude-location.longitude)+(person.latitude-location.latitude)*(person.latitude-location.latitude)) from location;
working out the distance in 3d-space between two points on the earth's surface is a bit more tricky :
person.x = sin(person.longitude*(2*pi/360)) * radius_of_earth * cos(person.latitude*(2*pi/360))
person.y = sin(person.latitude*(2*pi/360)) * radius_of_earth
person.z = cos(person.longitude*(2*pi/360)) * radius_of_earth * cos(person.latitude*(2*pi/360))
then do the same for location.x/y/z and then :
distance = sqrt((person.x-location.x)^2 + (person.y-location.y)^2 + (person.z-location.z)^2))
- in the units you use for radius_of_earth (assuming a spherical earth, which it isn't, but close enough)
The real distance you probably want is the, equation for the length of a geodesic across the surface of a sphere, but I forgot that one. Try mathworld.wolfram.com
Just a btw: why are you using -100/+100 for your units? longitude goes from -180 to 180 and latitude from -90 to 90
