Calculating Montiors DPI
Fairly basic maths tbh.
First find the aspect ratio of the screen by dividing the horizontal res by the vertical. This gives 1.6 for widescreen units, 1.333 for most non-widescreens and 1.25 for the oddball 1280x1024 resolution 17" and 19" units.
Now take the inverse tangent of this value to find the angle of the diagonal from the vertical, so 1.6 gives 58 degrees, 1.333 gives 53.1 deg and 1.25 gives 51.3 deg.
Now take the sine of this angle to give the ratio of the horizontal width to the diagonal length, so for a widescreen unit this is 0.848. Multiplying this by the diagonal length, such as 22 inches, gives the width in inches of 18.66. Divide this into the horizontal res, such as 1680, to give the DPI which is 90.
The other figure is the dot pitch, usually expressed in mm. To get this, divide the DPI into 25.4, which with 90 gives .282mm pitch
HTH :)
