Hi all,
I built a PC a while back for rendering out timelapse files.
Essentially using Adobe after effects to convert camera RAW images, to high res videos.
I have a similarly specced pc to a friend, yet his renders 10-20x faster. So, I'm trying to figure out where the weak link is.
i7-5820K 3.30GHz
Gigabyte GA-X99-UD4
MX100 256GB
Palit GeForce GTX970
32GB Crucial 2133MHz CL15-15-15 DDR4
Multiple drives in RAID 10
When I render, my CPU usage goes to 100% on all cores, and the RAM usage is also maxed out.
I have tried rendering files from ssd->ssd, and hdd->hdd, and the speeds are the same. This makes me think it must be a CPU or RAM bottleneck.
Any ideas how I can figure it out ?
Cheers
Paul
i7-5820K 3.30GHz
Gigabyte GA-X99-UD4
MX100 256GB
Cheers
Paul
