A few caveats:
the horizontal, vertical and diagonal angles of views are all different, just use that dimensions from the sensor. The lenses normally advertise the diagonal angle of view only.
Different sensor have different sizes, e.g. the 1.6x and 1.5x crop sensors.
Focal length of lenses are rounded up (or down), and can very depending on focal distance. E.g. the new Nikon and d Canon 70-200 are more like a 80-180mm at close focal distances. Lots of lenses claim to be 18-xxmm but they vary between say 17.4 and 19mm. plus or minus 1mm at the wide end changes the angle of view quite a lot, especially at the 10-12mmm on crop cameras.
That stuff is actually easy, the difficulty is knowing how far away the subject actually is, most people are not very good at estimating and you cannot (easily) automate that. However, you can offer a large number of fixed sizes like length or breadth fo football pitch, basket ball court. You could automate this to a certain extent, take a photo with he smartphone and have the user manually highlight a human and enter an approximate height of that person, you can then find the distance to that person with known camera parameters form the phone. I wrote a computer vision algorithm that did something similar, but it is very sensitive an accurate height measurement at close distance and at long distances very sensitive to how accurately the subject was selected.
