Calculator for server running costs
6 Oct 2004
Birmingham
Hi guys,
I'm in the process of putting together a proposal to upgrade our ~15 8-9 year old servers (don't ask) to a couple of high spec servers running multiple VMs.
As part of this I want to compare the running costs, and just wondered if there's a calculator anywhere I can use to generate the required figures?
I know the power ratings of the PSUs, but iirc it's not as simple as just using that as obviously they aren't running at full load/efficiency 100% of the time!
I did stick the figures in here:
http://networking.ringofsaturn.com/Tools/serverpowerusage.php
Which gave me a cost of ~£17/day - does that seem realistic?
Otherwise, anyone got any gems of knowledge or links to calculators?
Cheers :)
It's easy enough to work out.
A plugin power meter, or load information from a UPS, is the easiest way to find the load in Watts.
Divide the load Wattage by 1000 and then multiply it by the cost per unit and that'll give you the hourly cost.
£17 per day would be roughly 7 Kilowatts of load. With 15 servers that would be a load of about 470 Watts per server which is a credible figure.
Derp. I should have thought of that... :p
Yeah, they range from 300-800 watt rated PSUs so 470 is slap bang in the middle =P
So... by replacing with a couple of physical hosts running VMs on ~1100W PSUs I could potentially save the company £3-4k pa... spiffing XD
Cheers dude :)
If it helps you with the sums, a sample Dell R620 here is right at this second consuming 182W.
Spec is 2x E5-2630L 2.0GHz procs, 384GB RAM, 2x146GB 15k SAS disks. This is with a light-ish load although at full load it isn't much more.
A much busier R620 which doesn't have such efficient procs but has half the RAM and is under much more load is consuming 154W right now.
