- 1 Aug 2008
- UK
I have just started using Google Calandar, but one thing I've noticed it can't do is when you set you start and end time it will only allow you to select preset times that are at 30min intervals.. i.e. 7.00 - 7.30 etc. There will be occasions when I like to enter times at 15min intervals. I use Microsoft Office also and decided to try Outlook and this too has the same problem. Are there settings to adjust in theses programs to allow me do what I want or can you recommend another program that can be accessed from any PC.
