Mmm, odd one, I've had a bit of rattling on cars in the past when the pads haven't been perfectly seated in the holders... not had it on a bike though.
So is it when you release the brakes or during at the end of heavy breaking? So nothing in steady breaking?
I had something very similar, it eventually turned into a "tick tick tick" when moving a low speeds. Replacing both the spring, and top shim in my Brembo brakes solved it
Maybe you lost one of the little metal bits that secure the pads in? My Hornets ones were terrible, wouldn't be surprised if they had fallen out while riding at some point.
Yup, that's how I felt about my Hornet almost every day, then when I fixed it it used to take the whole weekend for a simple job. That's why I just got a new bike. Sounds like you need a new bike
This is true. I bought mine with doing as much tinkering as I can in mind. At least then I can learn without crapping myself that I'm messing up a new bike
