Caliper paint.
7 Dec 2002
UK
I have been painting a pair of calipers & carriers this evening however the paint seems to be really thin & doesn't want to sit evenly at all which is what i'd have expected spraying normal paint with no primer.
Is this normal or do I need to put 3 million coats of paint on these things?
For reference it is red paint that i'm using on what are essentially OEM spec cast calipers.
