Tesla said:I just use a normal G-Clamp.
Make sure that the end is not sharp so the caliper isn't damaged.
Chris
Dandle said:You cant wind back a rear caliper with a g-clamp as it has to be screwed back due to the handbrake. I have something similar to this, its worth getting one with different size heads in the box unless your only ever going to use it on the mondeo.
Oracle said:You dont need that either, just release the handbrake cable!!
Simon said:![]()
What.
You cant push caliper pistons in on pistons with handbrake mechanisms, they need to be wound in properly!
