16 Jan 2007 at 19:17 #1 stickroad stickroad Permabanned Joined 29 Dec 2006 Posts 3,817 Hi im tying to create a server, but when i ever do its never listed on the internet bit when i go to join game?
16 Jan 2007 at 19:21 #2 HangTime HangTime Man of Honour Joined 25 Oct 2002 Posts 31,924 Location Hampshire It's probably not reporting to the master server.
16 Jan 2007 at 19:24 #3 decmatt decmatt Soldato Joined 10 May 2004 Posts 3,790 Location East Yorkshire, UK You got the ports open correctly?
16 Jan 2007 at 19:38 #4 stickroad stickroad Permabanned OP Joined 29 Dec 2006 Posts 3,817 Ah the ports, any where i can find them out?
16 Jan 2007 at 20:01 #5 GarethDW GarethDW Soldato Joined 22 Jun 2006 Posts 2,971 Location Swindon This site lists the various ports you might want to consider opening up on your firewall... http://www.tmmworld.com/Default.aspx?tabid=42
16 Jan 2007 at 20:04 #6 touch touch Soldato Joined 28 Oct 2006 Posts 12,457 Location Sufferlandria make sure you have set the options to "dedicated" as if you just choose "internet" it wont work. You need to start the dedicated server (you get the small console window appear and your back to desktop) You then leave that running and click your CoD icon again, the game will load again to the normal start screen. You then bring up console and type "/connect <your own ip address>"
