Call of Juarez - help
6 Mar 2008
Stoke area
I can't see any bleedin rabbits :D
I ride around, hear rustling stop and look about but nothing. I haven't even seen any running back and forth :(
Other than that, what a cracking game. Anyone who hasn't played it I would suggest you at least try the demo.
Anyone know of any other games that use this game engine?
They tend to hide in bushes, run around the immediate area around the red dot on the map and you'll flush it out...easiest hit is if you're running straight after it.
Having real problems playing this game, had trouble installing it and now when I want to play the stupid copywrite popup box thingy can't read the disc :(
Every other cdrom seems to load up first time ok, its just this game and I have 2 copies of it (free with 2 products), both have the same problem.
Windows can't find it, although it eventually will if i keep opening and closing the tray.
Any way to bypass the copywrite popup? Any ideas?
Can you register it with steam and then run it without the disk? I haven't as I had no problems (aside from lack of triplehead2go support).
No idea tbh i only just installed steam cos it came with my ati drivers. Never used it before.
You can't register it with Steam, but you could try using a No-CD or No-DVD crack (both the same thing really). You could also mount an image using some image mounting tools :p. They might work.
As Mud say above get to the red dots (on the map) and just wait. The rabbits hide in the small bushes and then run between them. If you're in the right area you'll see a lot of these small bushes, so you just need to stand still and keep your eyes peeled.
When you see a rabbit take it out with an arrow (aim just infront of it as it runs).
