Call of Juarez, stuck
Suspended
17 Mar 2006
Just after meeting Suzy, jump out of the window and go along the back alleys. But where now? If I go onto the main street I get blasted. :confused:
That bit was so annoying, you cross sides 'n' jump a fence, then go through the houses if I remember rightly.. completed it a long time ago :)
The crawling to the train bit will test you if you find this bit hard :p
Souness said:
you need to cross the street to the backalleys on the other side
Yup, you won't get hurt if you get the timings right, sneak past or just leg it to the backalley on the other side.
How do you pronouce the name btw? "WA-RES"?
