Hi,
Just a quick post to ask for some advice. I joined a new ISP last week and my ADSL max came live on Tuesday 18th July. So I am now on day 7. (I migrated from a 1MB connection)
Firstly my setup: I have an ADSL faceplate instead of the BT faceplate and I am running CAT5 to my Netgear DG834 router. (Line stats are the same at the master socket so no wiring problems)
Ok heres my problem. Mainly in the evenings while gaming I am getting disconnections, now I reckon this is down to an extremely low Downstream SNR. My downstream stats at this precise moment are as follows:
Connection Speed: 4032 kbps
Line Attenuation: 57 db
Noise Margin: 2 db
Now I am pretty sure the low SNR is what is causing the drop outs. Surely ADSL Max should be starting to connect at a lower Line speed in order to up my SNR?
Is there anything I should be doing or that can be done?
Cheers
Noise Margin: 2 db
Cheers
