Calling all 3D Studio Max, V-Ray RT + GTX users
27 Aug 2013
We are in need of new 3D studio Max 2014 workstations and seeing the progress GPU rendering is making with V-Ray RT, we are looking for recommendations from users in the architectural sphere as we all handle large floor plates.
We are initially thinking a GTX TITAN and a GTX 680 as the TITAN is the only card with its 6gb of ram which is capable of loading the scenes. The GTX 680 with 2gb of ram looks quite capable of handling the viewports and as its Direct X these days, there is absolutly no benefit in Quadro any more. If a single TITAN is capable of giving adequate RT performance then fine otherwise we can add a second TITAN later.(its all about using the available CUDA cores as math processors, Not the same as gaming!)
What we can't find is baseline information with examples on the loading on the CPU's and the number of Cores required. From other discussion threads we can sumise more GPU's = More CPU overhead. The CPU is after all farming out its load to the GPU's to do the math but still performing the main threads.
We believe the two cards will probably use from 30% to 40% of CPU, Two TITANS probably upto 50% from listening to what others are doing, BUT this is conjecture and we dont know the CPU's they are using, only the Graphics cards !
We have reviewed the costs and main manufacturers of workstations and of course all are selling workstations with Quadros and won't consider 'Gaming Cards' so it looks like we will have to get a made to measure system or re-sell some Quadro's !
Currently we have Dual Xeon workstations and a decent Quadro. Simple RT testing on this platform works but the single card makes Max unuseably sluggish and across all 8 CPU cores it shows a continuous 50% loading while feeding the GPU the scenes.
We can't decide whether an Intel Core i7 3930X Unlocked (6 x 3.2 GHZ) would be quite adequate, an Intel i7 3770K - (4 x 3.5 GHZ) - Ivy Bridge which is far better priced all be it 2/3 the performance or do we need to be looking at 2x E5-2630 Intel Six-Core Xeon 2.3GHz 15MB Cache.
If we can go for i7 then there is a far greater choice of components and faster RAM, not to mention over-clocking where required.
Who of you have already made the move to RT, what have you based the workstations on and what are your experiences ?
As this will be in use for the next 4 years we need to make the right decision and our BOSS wants proof it is going to work as advertised otherwise its NO RT
ANYONE seen anything appropriate on YouTube to demonstrate V-Ray RT with large Architecture ?
Hey!
I currently use a 3820 (same socket as the 3930x) and for my 3d needs 3ds Max/Maya etc its perfect. I can suggest on the cpu side to go with the 3930x as a friend has that and he loves it with his 3d work too. Although the 3930x runs hot when OC'd. with good cooling you can keep this under control, so no problem.
Graphics if the titan is an option I would go with that myself.
