Hi all you Asus owners out there. I have a question re the fans on a P5E. According to the board spec, I have 4 fan headers on the board; 1xCPU (4pin), 1xPWR (3pin), 2xChassis(3pin). I've hooked up my two input front fans to the Chassis 1 connector via a splitter, the rear output fan to Chassis 2, CPU fan (4pin Arctic) to CPU (duh!) and my blowhole fan to PWR. All the fans are being reported correctly in BIOS.
Now for the questions:-
1. When I enable the q-fan feature in bios, the CPU fan NEVER gets faster than 650-700 RPM, no matter how hot the cpu gets
2. I disabled q-fan and loaded Speedfan instead. It reported only 3 fan speeds (CPU, Chassis1&2) but only gave me 2 fan controls (1 controlled the CPU fan and the other controlled the front/back chassis fans as a single unit). After running it like this for a week I'm now only able to control the speed of the CPU fan.
Can anyone recommend me some fan controller software that works with the P5E. I've sent the writer of SpeedFan a system diagnostic and he'll try to get around to adding it in the future. I was wondering what you guys do though to control your fans.
Cheers
Matt.
Cheers
Matt.
