- 3 Jul 2007
- Newcastle UK
Hey just in the process of putting my new build together. Mobo is installed, im onto the dvdrw drive. How is this best installed- there is 2 rails and then also a hole to put a screw into the side of it. How do you get at the side which is next to the front panel. Do you remove the front panel? or do you remove the whole dvdrw and hdd brackets in order to put the 2 screws in the side.
Thanks
Thanks
